Favorite BOV
Which BOV do you like best?
  • GReddy Type-S
    Votes: 57 31.1%
  • GReddy Type-R
    Votes: 3 1.6%
  • Turbo XS
    Votes: 20 10.9%
  • Blitz Dual Drive
    Votes: 4 2.2%
  • HKS SS
    Votes: 66 36.1%
  • Stock or OEM
    Votes: 25 13.7%
  • Other
    Votes: 8 4.4%
  • Total voters
    183
Originally posted by TurBoGs-T
2 RFL's. I didn't read thru the whole thread but is this on one car????? I don't get it.
You should read the thread atleast before you reply to a comment. If you don't know alot of cars with big turbos well you two blowoff valves to prevent any shock waves from going back against the compressor wheel.
My favorite is when I boost down the street with my head out my window. Then I can scream "PSHHHHHHHHHHHHHHHHH" everytime I shift. Tough to do in a helmet though so you might need a megaphone.
My girl does that when I ride with her in her Camry.:D
You should learn to type before you reply to a comment ;). I've seen some huge turbo setups but never two bov's :rolleyes:
Well alot of trees fall in the forest but I've never heard one? I guess they dont make a sound!:shhh: Its common scence that if you start flowing more air eventually a 28-30mm valve in a short time is not going to be able to vent all that pressure between a shift. Common scence is not so common, thats why most big turbo cars have large valves like godzilla, greedy, tial etc..
does the ssbv sound similar too the type-s but with a deeper sound?i know the turbo xs rfl sounds great, but i kinda like the little high pitched noise at the same time. what sounds better out of the 2?:confused: :dsm:
I like the crisp sound of the turboXS valves...
yes... the HKS (when vented) sounds like minnie mouse sneezing... so if you like that high piched fluttery chirp... then the HKS is kewl... I think it sounds kinda fruity... but that's just me...
I'm more into performance to thats why I was going to get rid of my RFL for what appears to be a better flowing TIAL>
1g bov's leak at idle. if it wasnt leaking, then it would be time for a new one. 1g bov is actually a cbv, not a bov. and the 1g cbv HATES to be vented.
"1g bov's leak at idle. if it wasnt leaking, then it would be time for a new one. 1g bov is actually a cbv, not a bov. and the 1g cbv HATES to be vented."
They will not leak, and will hold 25+psi if you do the high boost mod(not crushing). Here is the link that describes the procedure.
http://www.thedodgegarage.com/turbo_bov_mod.html
However, you shouldnt even be thinking of venting it unless you are able to... THE CORRECT WAY! Even recieculated, this mod will help. Once again, only 2 valves I would ever use. The 1G CBV,(for those that have to recirc) and the TIAL, (for those that can vent).
Dejon tool also offers a similar type mod to the 1g CBV. I had a 1g CBV and it wouldn't hold anything past 18psi for crap. Although I have seen several stock un-crushed 1g CBV's hold 22psi, without any crushing or modding. My GReddy Type-S solved all my leaking problems and it works flawlessly. I agree, TIAL's are great also, along with there external wastegates.
The "Minnie Mouse" sound is only on mostly stock cars running low CFM(not PSI). MY HKS SSQ got a hell of a lot louder when I put on my FMIC and pipes and I started running a larger turbo. If you put my car and a stock one next to each other with the same valves the sound would be totaly different. My valve (when at high boost) sounds similar to the Tial that my friend was running. The HKS is a great valve because it uses two springs. One spring is for low boost when at low RPMs (sounds like fluttering) and a large spring for high boost (sounds mean as hell). If you don"t like the sound of the valve you can either change the insert for a higher or lower sound or recirculate.
i have a HKS super bov , non seq Sounds great...push/pull type still, but it looks crappy under the hood :|
my friend has a greddy type R sounds great under high boost
Btw i see lots of duel BOV setups, probably more then single bov setups
Turbo XS H34. When I roll with my two buddies that both have Greddy Type S valves the H34 just drowns them out. That and the Type S sounds like a high-pitched kazoo....Holds 21 psi great and is louder than a MF recirc'd. Not big on how it looks but you gotta give somewhere.
Tom
I have a a saxaphone hooked up to my blow off valve. It's mad pimp yo, because all that matters is how loud my BOV is. All the chicks down at the local Dairy Queen want me when I make my car sound like it's a big rig's air brakes. :rolleyes:
I have a TiAL and flows much better than any valve ive tested(HKS, GReddy, 2G:rolleyes: and 1G) Its a great quality valve that comes with its own flange and everything ready to go. Its not the lowdest thing with the T25 but now it sounds close to what a recirculated Type S sounds like. If i ever want a loud sound again i might change as far as right now all i care is for performance so im stayin wtih the TiAL.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
