Fans Location. HELP!!
MXD
81
Dec 12, 2004
Queens Village, New York
Hey guys, due to my turbo/intercooler piping set up, the installation of cooling fans is very very tight even with slim line fans. I have no A/C but i am installing two fans. My questions is... Is anyone running a fan in the factory location and a second fan on the other side of the radiator opposite where the original A/C fan was?? This would clear up a lot of needed space. Is anyone running a similar setup having success or any issues?? Help Please
The turbo is a SCM-61 with 3 inch intercooler piping. The fans barely fit but it doesn't look asthetically pleasing as i would like it to look. Im just looking for a little feedback. Thanks for your response so far.
I have them set that way in my Galant. The stock location for the a/c condenser is set as a pusher due to space restrictions. Most aftermarket fans require reversing the blades and wiring to change them to a pusher setup, so be sure you test the fan before you put it in there.
If you can mount 2 pullers, I would. If you really don't like the way it looks or it's too close to your intercooler piping, exhaust mani. etc and you just don't want it that way, then mounting the second fan as a pusher will be fine.
