Factory Brake Line Routing?
Lolmooses
73
May 26, 2014
portland, Maine
Hello ladies and gentlemen, I have a 91 GSX non-ABS that has some questionable rear brake line routing from the previous owners. Its currently running below the subframe and here in Maine they're strict on having the lines in OEM location or as close as possible for inspection. My question is, does it run above the gas tank or subframe? If not, where?
the lines should run along the side of the under body frame rail. The square rail that's under your passenger and driver seat. One side may be fuel lines, the other side should be brake lines. Then they will go up toward the gas tank, then switch over to a rubber line to your calipers.
  • Wanted 6 bolt NT water pipe
    • chrisman287
