2G F5M31 Euro NA tranny
Exxxel
99
4
Mar 18, 2006
Italy, Europe
I want to rebuild my transmission, but I can't find any rebuild kit over the net...
Can anyone help me with some input/data?
Transmission code is F5M31-2ZVZT and came stock on my 1997 2g GS N/A (4g63 platf.).
F5M33 kit will work on this?
Noticed that 2g spyder uses also F5m31...it is the same?
It is the same. It is no wonder you are needing to rebuild your tranny, as that is a NT tranny. It is possible the parts are interchangeable, but you would need to replace everything to get the strength of a F4M33. Maybe buy one and have it shipped? Direct swap.
I have a friend in Spain that keeps telling me about the trannys over there have a much closer ratio and better gearing than the 33, as he has driven a car that was imported from the U.S and compare it to the ones there.
Could this be the same trannys, I would like more info on this if you guys have it available
Here are some more data about F5M31.
