extremepsi fmic ????
Fitment is perfect. Friend has one, the cast endtanks are nice as well. SLS also sells this, and i think buschur has also switched to the same core.
YES, the extreme kit does fit the 1G with ABS, as a matter of fact it will also fit with the AC, power steering(minor piping adjustment needed) AND AUTOMATIC with a trans cooler. The radiator side supports need to be trimmed out and the opening made larger, also loosing the fog lights helps. Aftermarket smaller fogs will fit the stock location. Trimming the steel bumper support is a must and some of the bumper cover also. The piping is 2.5" from the turbo thru the IC to the throttle body and fits well with minor adjustmenst.
Here are some install pics of my ExtremePSI Street core.
Rad support hole enlarged.
The IC mounted and LICP thru rad support.
Full shot how much of the steel bumper support needs to be cut.
IC mounted with bumper support installed.
Last, finished install.
UICP and the ABS plus a GM MAFT Blow thru.
thats some good pics you have there i am ordering their race fmic and was wondering the fitment of the ic but you have answered my ? :talon:
why does your spark plug cover say "vtec" on it? i know the pic is cut, what was the rest of it say?
Thanks Guys For All The Info And The Great Laughs From The Valve Cover..i Want That Shit...that Is Fukn Great Piece Of Work.....
ddimestalon said:
Hey turfnnsurf. What UICP are you using? Is it custom, or a certain brand?
The UICP is from the ExtremePSI kit, I just cut the BOV pipe shorter to fit the GM MAS and couplers. As you can see it's a tight fit between the ABS unit and the Trans fluid dipstick. After New Years I'll be getting a custom UICP made for my Greddy BOV and the GM MAS.
I picked up a Very nice IC from EBay. Makeing the piping is easy. check it out.
Sparco Intercooler
Deal looked sweet to me. It will arrive day after christmas..
yes i compared the extremepsi kit to that linked on ebay and it is diff.....thanks for the heads up...
  • Wanted 6 bolt NT water pipe
    • chrisman287
