1G exhaust manifold stud oil leak
93AWDDSM
883
40
Jan 1, 2009
Vancouver, Washington
Hey guys,
I've seen at least, 5 if not more (definitely more) threads regarding the oil leak by the manifold stud/s. The only thing is most of the posts said "well, it's some of the studs" or "it's the stud in the center". Can someone point me in the right direction as to which specific Exhaust studs have the potential to leak oil.
Thanks.
The center one on the bottom is the only one I can see for sure goes through a oil passage on my spare head here. If you pull the studs out you should be able to see which ones do.
