Exhaust manifold removal.
I-luv-em-all
602
5
May 25, 2004
Regina,
Hey, I am trying to take off my 2g manifold to toss in some new gaskets.
All of the nuts/bolts are off, but I can pull it off. The exhaust manifold to head are studs, and there is that 1 stud on the turbo to manifold, so how the hell do you lift it off? If I really pull on it I can almost get the manifold out of the studs coming from the head, and then I would have to lift the manifold out of the stud coming from the turbo, but I don't want to break anything, their has to be an easier way, any hints/thoughts?
you can remove the stud on the turbo, and replace it with a bolt. a lot easier to r&r the exhaust manifold
drill and extractor???just take off the turbo,stick vise grips on the stud,and pull it out.then replace it with a bolt when you re-install it.
i was very lucky when i did mine it just unscrewed very easily. i could imagine this being a big pita. i did the double nut method. this is done by tightening two nuts into each other until you are able to put a socket on the top nut and extract the stud.if this doesn't make sense pm me. you will have to pull the turbo off the first time because it is impossible to pull the manifold over that 1 stud.
hope that helps
why must you all make it so difficult he can leave the turbo in and take the stud out, take one of the nuts for the stud use a wire feed weld it onto the stud and use a ratchet to take it out... walla :thumb:
You can remove the exhaust manifold without removing that stud first. I just got done doing it on my 1g. I used a small pry bar batween the turbo and manifold prying them apart as I pulled the manifold of the head studs.
  • For sale 4G63 Competition Clutch, Clutch Fork
    Competition Clutch, Clutch Fork $75 + shipping and PayPal feesYou must be registered to see...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
