Exhaust mani and .70 turbine housing fittment
cjridert1
403
6
Jul 4, 2007
Akron, Ohio
Anyone know if a BEP .70 turbine housing will clear the block with a turbonetics/treadstone exhaust mani? I had plenty of room with my .55, but not sure if this will. Car is in pieces, engine parts are @ shop, so I cant check fittment.
Thanks
It should be known that there are two different turbo flange angles on this type of manifold. The true Turbonetics manifold has a much steeper angle than the TN knockoffs that I've seen, and would stand a better chance of clearing the block.
Ehh, so this is less likely to clear the block. Anyone actually try fittment with one of these guys? Also, FYI, the treadstone manifold with a 38mm tial will not easily fit. I had to cut my one hood support frame deal and dent out the hood just so the wastegate doesnt contact the hood.
