exedy clutch mbd081u / please help me
RayBan GST
665
4
Oct 21, 2007
DUBAI UAE, Asia
hi all,
i need your help please i am buying today an exedy clutch kit but i really can not tell the difference between it and between the non turbo one
its EXEDY made in JAPAN part number on it is MBD081U and then on the other side there is 6M01
the shop does not know if its for Turbo application all what he knows that its for 4g63 engine
please help me here he is selling it to me for 100 USD and i need to know if iam buying the real stock replacement or at least mabye stage one . can you tell me how to check or tell the difference
i do not want to buy another brand i just wanna make sure that this part number is really what i want MBD081u ( i searched in the forum but could not find)
thanks
Going on Exedy USA I searched your part numbers but it came up empty. However, I found this list of OEM applications
EXEDY Globalparts Corporation | High Performance and OEM Clutches and Flywheels
Also interesting, the part numbers for the OE applications and the stage one applications are the same:
According to those lists, they don't make a clutch for a 2g non turbo, so I think you should be ok. That being said, all those part numbers are different than the ones you listed. If I had to guess, I would think you would be ok with the clutch, as I see no reason why a Japanese clutch company would make a product for a motor (420A) that never was sold in Japan.
A google search of MBD081U got me this thread which says that MBD081U is a part number for the disc itself that will fit a 7 bolt 4G63T. Clicking on various Japanese and Russian (?) sites with that part # all showed a clutch disc, so I think that disc will fit. Searching 6M01 got me no hits other than this thread. Do you have a part number for the pressure plate? At this point I'd say its likely that it will work on your car, if nothing else the disc will, but I can't be sure about the pressure plate. Whatever kit that is, it's a stock replacement/stage 1 kit with an organic street disc designed to fit Mitsubishis and other cars that use Mitsu powerplants (Hyundai, Kia) . I can say that according to Exedy, the part number you want for the entire clutch kit is 05800. Hope that helps.
