EVO3 o2 housing and APEX GT downpipe
clipseturbo97 said:
Can anyone tell me if the EVO 3 o2 housing will bolt up to my APEX GT downpipe?? Thanks
nope unless u modify it, just the stock 02 will work with the apexi,i have apexi gt dp w/ an o2 dump i dont know what brand though
Lets try this again. First time I tried to submit I got a 'Page not Found' :mad:
No, the stock o2 housing will not fit the Apexi N1 or GT downpipe because it has a different angle. This is the angle difference.
www.122performance.com sells an EVO style o2 housing for use with 2G style downpipes like the Apexi N1 or GT for $195.
"EVO style" 02 eliminator (2.5” with tie-in, for internal gates) - We made this piece as a direct replacement of 90-99 stock 02 housings. By the time you buy a EVO housing and have it ported, it will cost more, and the angle of the EVO outlet along with bolt distance is different than your factory 02, which could cause fitment problems.
www.roadraceengineering.com also sells 2G downpipes for the EVO o2 housing for $230
If you have the upgraded EVO O2 sensor housing, order the EVO style DP. It comes with the larger EVO bolt pattern and is angled correctly for those cars running the EVO O2 housing
I believe it is possible to get the evoIII housing to fit your std. apexi downpipe, but it isn't recommended. Like has been said because of the different angle of it compared to the stock O2, it puts alot of stress on the flex section & will more then likely cause it to fail. As far as I know the evoIII housing also has a larger bolt spacing but on most downpipes it is possible to elongate the holes to make it work. Can be done, just not the proper/best way to do it.
daren_p said:
Like has been said because of the different angle of it compared to the stock O2, it puts alot of stress on the flex section & will more then likely cause it to fail. Can be done, just not the proper/best way to do it.
Agreed, IF done, will not last you a long time.
