EVO3 16g or other engine mods??
gobeli67
51
May 31, 2006
Grand Blanc, Michigan
I have been debating what I should get for X-mas. I can either get an EVO3 16g or I can get other mods. My question is should I get the EVO3 now and hold of on other things like a logger, cams, header, ect or should I get those things first and then get the turbo. Let me know what everyone thinks. Also if I got the turbo could i run my stock fuel set up or would I need a new fuel pump and injectors.
Looking at your parts wish list:
T4 turbo FMIC 7 bolt 2.4L Stage V head 3" lowering kit 92' front clip conversion body kit big brakes
and the fact that you're already making 290hp... I'd put the money into more supporting stuff and then go bigger on the turbo.
if you dont have a logger.. and you are running nos with 600cc injectors plus a translator.. yeah you should have got that a long while ago. Looks like you could use some upper intercooler pipes and that intake pipe replaced.. get rid of that rubber crap. Impressed that you can get away with the stock pump with those size injectors.. upgrade that and get an AFPR to go with it. Then you can go ahead and drop in an EVO 16g if thats what you want.. and I would consider doing an intercooler upgrade after that to really be able to get that boost up.
  • Wanted 6 bolt NT water pipe
    • chrisman287
