Evo III cams...?
bOOstd GSX
931
Nov 29, 2003
Plum, Pennsylvania
I was told recently that the Evo III cams are the same duration as HKS 264's or maybe another HKS cam. Is there any truth to this? If not, does anyone know what the duration would be and how it could affect my performance in my 2G gsx ina good/bad way?
I have a set of cams i recived with a package deal i bought. They are used but clean the only marks i find on them are a ES imprint and 4604 imprint. Anyone have a clue.
evo 1-3 cams will work and are an upgrade for your eclipse, hell ive been told that even the 1g cams are an upgrade for us 2g guys. but as far the evo specs. and in comparison to the hks cam, im not sure but and would also luv to know.
LOL guys how much more aggresive are the evo3 cams than the 2g turbo cams?
Evo 1-3 motors are exactly the same as 1g 7 bolts. If there was a difference in cams, then it would be commonly pointed out as that's the difference. But it never has been said. So bet on them being exactly the same.
The difference in 1g and 2g cams is not noticable. Do not bother.
Thank you for clearing up 1,832,758,237,589,273 posts worth of garbage up. :laugh:
my friend got a stock intake cam and an evo3 exhaust cam on his 90 laser, shit idles kinda lumpy
evo I to III engines won't bolt to a 1G ... they are more like 2G engines
Try not to speak.
Those are direct bolt-ins.
And he's probably losing power on his setup, just because it idles lumpy doesn't mean it's making power.
Probably idles lumpy because its a dsm.
Evo III Cams do work. I use them in my 2G. They have a 10% greater lift and duration than the stock 1/2G cam.
HOLY DIGGING UP 3 YEAR OLD THREADS BATMAN!
but just to input the facts-
yes evo3 cams are an upgrade and so are 1G turbo cams... and the part that you should Know already if you did your research...
evo2-3 cams are the same part number as 1G turbo cams!
2g turbo cams are the same part number as evo 1.
hasent this been :beatentodeath:?
/thread
