2G Evo 8 brake swap squeaky
A13x760
Mar 11, 2025
Thousand Palms, California
I have a 2g I did the Evo 8 Brembo swap. Anyone that can recommend me brakes, I tried a few pads Brembo and a Duralast ceramic and I hate hearing the car squeaky on every brake I do. thanks
Did you even wear the pads in yet? Some take some time to bed properly. At least 100-500 miles if street pads and also depends on prior compound deposits left over can also be an issue.
I have i replace them already 2 times i even resurfaced the rotors because they where damaged the guy who had it before me didn’t have the calipers mounted right until i saw it and i ran the car on every pad for more than 1k
have you tried adding a pad backing sheet so the softer anti squeel stick on backs? These can help in times like this.
Yup i have it worked for a bit but a few drives and started making noise again i was searching on youtube sone people recommended stop power ect pads but i wanna see who uses what and if they worked i check the caliper and their good
i have used carbotechs without noise, only when light braking as its normal to get that, and that's a race pad so not sure on your situation. something seems off as i had used 3 pad compounds on my older brembos. ebc can be very quiet
Do you remember which ones in tired on that noise every break and is only coming from the driver and its loud af 😅
No sorry it was years ago, I’m still trying to get mines driving or better yet, stoping.
I installed a 3g MC to aid in brake feel but currently having an issue with leaks.
