2G Evap delete
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
So I'm trying to continue with my delete/wire tuck and I have all the lines delete so far but now I have a line that goes back to the gas tank I'm assuming and I dont know what to do with it, I know one line from the tank goes up to the throttle mani and there is another that went to the evap, now should I run that to the throttle too or should I have that line run out under the car? open or closed ?
If it's anything like the turbo models, there's one that's a vent for the fuel tank, and that one should be left open, and secured somewhere out of the way so it can continue to vent without being clogged.
I'm sure it is like them... as of right now I have it running out of the bay by the tie rod is that good
Alright thank you, now another side note when I go to get gas the pump turns off and takes for ever to fill up why is that? The gas dosnt seem to wanna come back up the tube just shuts off on me like it's full ?
Hi, Looking for similar advice on doing a clean removal of my canister on a 1G NT. Would sure appreciate if someone could comment on my below approach to see if I am doing this correctly. Many Thanks.
https://ibb.co/fpSTbJv
https://ibb.co/BczFVmv
Also, does this mod create any noticeable issues with the car? I know there will be codes thrown but any impact to driveablity?
