ETS behind the scenes - Our intercooler quality control process
ETS Michael
45
Mar 23, 2007
Vancouver, WA, Washington
To give you guys another inside look at our processes I decided to cover the quality check that every intercooler we sell goes through, from completion in the shop to boxed and shipped.
Once completed, every intercooler is pressure tested in excess of 35psi to ensure that you'll never have a leak, even at the highest boost levels. This particular one shows the gauge at 50psi with no leaks.
As soon as the intercooler passes the pressure check, it is moved into the staging area where both sides of the core are thoroughly inspected and any bent fins are straightened using our modified fin pliers {thumbup}
Once there are no imperfections on either of the fin surfaces, any tungsten strikes (black marks) from welding are cleaned and removed for a perfect exterior finish. Inlet/outlets are inspected shortly thereafter for smooth port transition and are cleaned to ensure they are dust and debris free for the safety of your engine.
Following those steps, all exterior surfaces are cleaned to make sure that while you're receiving the quality and attention to detail that only hand craftsmanship can provide, that it is completely clean and void of any dust, dirt or fingerprints from its handling.
The final step ensures that the intercooler you order shows up in the same perfect condition it left our quality check desk. Inlet/outlets are taped up to keep peanuts and dirt out, while the front and back faces of the intercooler receive cardboard side boards to make sure all the fins stay straight and dent free in transit. Piping is individually wrapped in foam before the whole package is doused in packing peanuts for a safe trip to your front door!
Almost ready to head out the door!
Can I come work for you (tig welder)? I worked (currently there) 2 years in production building aluminum truck mounted petro tanks, fully certified tig welder. I also build all their stainless pipework for the main discharge pipes on the trailers. Just a thought anyway.....
Your intercoolers look awesome. Seriously. I've been looking around for a setup on my 1G and have been debating between yours and two others. Just wish they wern't so expensinve........:D
I live in Bangor, Maine. What is included in the kit? All pipes for a complete bolt? That's a price that sounds convincing. Maybe some sweet talking to the wife and it will be mine LOL.
One question - does the company utilize end tank flow dividers in the design/fabrication?
At least in the old kits, you need spacers or shorter bolts for the TB because the ETS flange is thinner than stock. But other than that, very nice looking/well engineered kits!
    • george bromwell
    • pma1123
    • Sdcryan1
