EPROM and DSM LINK
Most 1995 AWD came with the Eprom ECU.
if you want to check Pull the ECU out from behind the stereo (ie: by taking off the kick panels and unscrew the ECU by using 10MM socket or wrench, there are 3 bolts)
On the ECU you'll see a white label and in the bottom right hand corner there will either Be an "E" or there won't be. If there is an "E" then you have an Eprom ECU.
Then you are set to buy the DSMLINK. (Which is basically a replacement chip for your "E-prom Chip" that allows you to interface with your ECU via laptop, that's just a general statement)
