Engine Temperature Gauge Reads WARM when engine is COLD
M3BEAST
Dec 16, 2007
In the garage, South America
The engine is COLD after sitting overnight. Then when I turn the car over. The gauge reads WARM at the 3/4 level right away. WTF?
Is this normal? Sensor is cool. No CEL? Coolant is new with H20 and thermostat is NAPA Quality.
Do DSM engines read WARM/HOT always after a COLD start?:dsm:
That's not right. Does your car overheat at all? If it does, it could be a water pump or head gasket. If not, then it's probably the temp sensor at the bottom of the radiator or on the thermostat housing, I can't remember which.
Coolant temp sensor is at the thermostat housing.
There is also a temperature sending unit or w/e right next to it.
You could check those out.
Its gotta be a sensor, i dont care what kind of car you have if its cold and jumps to 3/4 as soon as its started its a sensor
What's the spec to check with a DVOM for resistance. Don't want to buy a sensor and then not the problem?
Would exposed wires on the harness be an issue like short to ground on the thermo housing.:dsm:
I just had the same problem and fixed it today.. It was one of two things.. the last owner had wired up the sensor(2 wire) and did'nt use the connector. they just used push terminals which were loose causeing crazy readings in my dsmlink.. I replaced the connectors and made sure they were tight sealed it all up and now no more bounceing of temp readings with dsm link.... also theres a single wire sensor on the bottom of the thermo housing which is the one that controls the temp gauge in the instrament panel. "most likely the cause of your problems." the wire was loose/frayed fixed the wire and it fixed the problem..... hope this helps.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
