Engine Seized
talon_42o
95
May 24, 2006
Essex, ON, Canada
Ok so I had a local guy do a 6bolt swap. This guy is well known in my area for doing DSM's up and has a good reputation. I brought him a full 1g running car with a bad tranny(no second or third gear) the deal was to to take out the 6bolt and put it in my 2g. Straight up swap full 1g motor. So I had him replace the water pump and timing stuff belt etc. So this engine has been sitting for a while b4 it ran 6-8 months, he did a comp test and got 165 across the board. So time comes to start the engine and he said it started real quick ran for a min and shut off now it appears to be seized. What could have gone wrong ? I just don't see how a running engine seizes like that oil pump ?? or timing setup wrong ?? Any input would be helpful. He took the valve cover off and looks fine in there. I had him keep the Balance shaft and replaced the belt Let me know what you guys think this guy isn't shady and has a good reputation for building fast dsms. So I mean people make mistakes but this guy wouldn't cut corners. WTF
Possibly too much tension on the timing belt, which spun a balance shaft and locked it up.
It could have been a poor tune that went super lean.
It could be a valve broke and is wedged in the engine.
There are a ton off different scenarios, but it will be obvious once you get the engine apart.
How could it have to much tension on the timing belt if it's an hydrolic tensioner ? Probably missing oil or something hit the valves... 165 psi compression is 15 psi more than stock for a 6 bolts. Open the block and look for some broken parts.
Did you crawl under it and try to turn it by hand? you should probably pull the head or drop the oil pan to see if anything is broke.
Im also running a 2g head with evo3 intake on my 1g its a great combo
