oldman
DSM Wiseman
- 9,789
- 196
- Jun 21, 2003
Dayton,
New Jersey
Hey guys, I blew my HG due to excessive crank case pressure.
Does anyone have links to tech article about engine rebuilt and parts check list like the one on vfaq for timming belts? I need to do a cost analysis so I can determine if I can afford to rebuild or just pull the head and change the HG. Thanks.
, If you've ever rebuilt or seen the insides of a turbo you know this is total crap. High oil pressure will not blow the seals out, however, the gaps in the piston rings (thats what turbo "seals" are called) allow oil to pass through when exceptionally high oil pressures are reached. Run the car for awhile and see if the smoke goes away slowly. Blue smoke only comes from oil when it is burned. White smoke can come from oil when it is "smoldering" in the exhaust. This is likely the case with you. Clean your IC pipes out too. While the exhaust is normally the culprit when itcomes to oil leakage, the thrust collar piston ring can leak too (into the intake). Maybe you'll get lucky and it will not be the HG!
I'll get back to you guys ASAP. Thanks again.
High oil pressure won't cause blowby past your piston rings, but high crankcase pressure will.
