Engine rebuild help/recommendations
freak4jesus_bt
109
Jun 1, 2004
seligman, Missouri
Well I just ordered rings,
rod bearings
full engine gasket set
clutch
water pump
and one wheel front wheel bearing for my car.
It's completely stock for now until I can start modding later on. I'm married so the cash flow isn't like it used to be.
But, anyway, I know I'm going to need a torque wrench.... but what other tools am I going to need in order to do this, ie cylinder hone????
I've got an engine hoist and stand, but I'm not for sure if I'm missing anything else. i've also got the tool to put the rings on...I think I still do.
Thank you for your help. Oh, and I'll try to take pics of everything when it goes down.
Brian <><
other tool I had to go out and buy that wasn't "normal" when I did mine. Are you doing the HG? Get some ARP's if you are, you'll thank yourself later. Make sure you have a 1/2 and a 3/4 torque if you can too.
I got some arp off of ebay for $5. It said they were used arps, I just hope that they are.... thank you for the reply, any other replies are welcome.. :cool:
  • Wanted 6 bolt NT water pipe
    • chrisman287
