Engine Noise after clutch swap
jmerrill
91
Oct 13, 2009
Calgary, AB, Canada
I just purchased an 92 Talon FWD TSI. I replaced the clutch as it was going. After I replace the clutch. I did the oil. I hear some tink noise. But you hear it at idle and when the car is in neutral. When the turbo spools out it goes away. Anyways suggestions. I have new lifters, i thought that might be the problem. But I am not to sure. If you think its the lifters, is there any secrets in how to do them? :banghead: It has 5W30 semi synthetic oil in it. Is there anything you guys would do while doing the lifters?
yes the throw out bearing was replaced. As was the hubs, wheel bearings drive shafts and rotors and brakes. And some engine seals.
