Engine fan question
jongreene
484
6
Nov 3, 2005
midland, Michigan
I noticed when the fans turn on, only one spins, then when the one shuts off the other does about 2 rotations. Is that normal?....never had any problems just confused about it.
Mine has done the same thing for many years. Don't worry about it.
If your worried about it any, drive the car till it warms up. Then sit somewhere and don't move, watch your temperature gauge and see if it starts to overheat. Our cars heat up fast and will overheat fast. If it doesn't overheat then you are fine. I haven't noticed what you are talking about, but that is because my fans are hardwired into a switch(thanks to vfaq). Test won't work if your driving over 40mph, so if you do it make sure you are parked.
