Engine code p0443 should I be worried??
98talondb
Sep 1, 2011
Shelburn, Indiana
I recently been having trouble with my 420a eclipse spitting and sputtering fixed the problem it was a fuel pump. 3 weeks later it's back to doing it ran the codes and got p0134 and p0443 I know it's the upstream o2 but should I worry bout the evap code? I am gunna test fuel pressure tomorow to make sure it's not the pump also but I'm leaning towards the bad o2 if anybody can help with the evap I'd help a lot on this quest to a perfect dsm again :)
A fault in the EVAP system probably won't cause the symptoms you described. Fix the O2 sensor problem then see where you're at.
Thanks man I'll head to oreilleys when I get off work hoping that's my problem. So I should ignore the evap code
