eliminating EVAP canister
talon_boy69
110
Nov 5, 2002
just a question...when eliminating the EVAP canister...what to do with the line that comes from the fuel tank??? seal it or what??? if you seal it while the fuel level is going down it would create more vacum inside the fuel tank , but does this have any side effects?? if you don't plug it you will have gasoline vapors all around the car and this isn't any good also..so..what to do with that?
Just run a piece or hose from the hard line to the underside of the car and point it towards the rear of the car. Just dont plug it.
Some people might be worried about something getting in there and plugging it, then just place a little cheap filter from autozone (kind of like the ones peole use on the valve cover vent) to prevent that from happining.
That's what I did.
