Electronic Boost Control
neuralracing
770
Jul 16, 2003
San Juan, Puerto Rico, Central America
What is the difference between the Profec B and the B Spec II? I read "built in boost pressure display and optional features like real-time, peak or last boost display (in either kPa or PSI)"... is the display accurate to replace a boost guage? Or should I get a Boost Guage anyway?
Should I stay away from the Spec II (I've been reading software issues with the Spec II)?
I've also been wondering the same thing and haven't been able to find the answer anywhere. I'm very interested to hear responses to this.
I just bought the "type-s" and it worked great until I tried to turn the boost past 25 psi (would not let me no matter where I set the boost/gain knobs)
I called Greddy and it needs to be sent back to them for an "update" :|
At least they know there is a problem and they will take care of it as soon as I send it. I can live with that.
Jd
Alot of the cheaper EBC's can't hold past 20-25psi, the older profec B couldn't either. MOst of the Blitz Dual Solenoid EBC's will hold up to 40+.
Can someone confirm that an EBC can also be used as a Boost Guage (Digital Readout)... how accurate would they be?
Since you 'T" it into a boost source yes it would be accurate.
When I had my Blitz SBC-ID, it would read the same boost as my boost gauge.
Which EBC would you guys recommend considering I plan on using it as my Guage as well? Would be cool if it had a nice display... Any feedback on the Greddy E-01?
