electrical problem... None at all
solo92s10
149
Oct 16, 2005
Elizabethtown, Pennsylvania
On saturday i installed safc2 and after the install i tried to start my car and nothing. So i thought that it was the safc causing the problem so today i disconnected every wire and same thing is happening. I checked all fuses and all are well. The only place i can actually see that i am getting electricity is right off the battery. Is there a main relay anywhere that might have went? Where should i go from the battery to check for power next? Ive checked engine fuses and none of them are getting power. Any suggestions will be helpfull.
One thing I would do is trace back what wires you used to hook up the controller up to and see where they run to. Maybe you can find the problem that is causing it. I would also check the ecu that might be a shot in the dark but it is worth checking.
i would check the altenator relay in the fuse box...it looks like a giant fuse should be a 40 amp or something like that
