BrokenPOS
- 46
- 0
- Dec 21, 2008
Denver,
Colorado
i'll try to keep this short...
car was running awesome for most of the day. then, the car started sputtering, and the lights (brake, low coolant level, battery, & cel) on my dash became dimly lit. drove it less than a mile to my house and parked it. tried to start it the next day, and nothing. the brake, low coolant level, and battery remain lit even after clearing the cel. tore out the alternator and took it to be tested, they say it passes. battery is reading 12v, coolant is full, and my parking brake is definitely off
. tested the CAS and CPS, both are working fine but i have no spark. fuel gauge is reading a steady 47 lbs. compression is 150 across the board.
basically, i'm beyond frustrated at this point and i'm posting this here because this car is making me feel like a SUPER NOOB. am i missing something?
. tested the CAS and CPS, both are working fine but i have no spark. fuel gauge is reading a steady 47 lbs. compression is 150 across the board.basically, i'm beyond frustrated at this point and i'm posting this here because this car is making me feel like a SUPER NOOB. am i missing something?
my car does this too for some reason, let me know if you find a solution
BUT still no spark
did my voltage regulator burn anything up before i got it fixed?
