talon20g
- 206
- 6
- Mar 21, 2007
WHITAKERS,
North Carolina
Well... I'm not very good on the electrical side of things. With that being said I ran into a problem today. I started the car last week and everything was good. I go to wire up the fans and before I start I was going to check and see which wire was hot and which was ground as they are universal fans and have to be wired in. I hook the battery up and (POP) the main fuse under the hood goes. I did cut the two wires for the boost solenoid off and the wires for the water level sensor, thats it. I did notice the post on the alternator were the 2 10gauge wires connect had a melted spot on it. Is it possible for the alternator to ground itself and cause this issue?
I did briefly search on google and nothing came up. Thanks for any help.
