92whitephantom
- 48
- 1
- Jul 9, 2002
OK I finally got my talon back up and running after almost 8 mths of being down. This may be long so beware. Got a motor that had 800 miles on the short block, and a freshly rebuilt head. I am having a couple of problems already. The car is a 1g
1st- car overheats under boost or a heavy load....new thermostat, water pump, gaskets, cap (rated for 16lbs), new head gasket. Did a compression test 150 across all 4 cyc., checked for any leaks, did a rad. Flush. No fluid in oil. Fans are running
2nd- when breaking the steering wheel vibrates badly. All rotors are new as well as pads. Proper tire pressure is in the wheels. New ball joints, and inner and out tie rod ends. 2 new front axles, wheel alignment
3rd- for some reason my shutter box no longer works. Checked all wiring and still nothing
4th- the motor itself has a banging noise coming from it. Only happens with high rpm's, about 2500 +. Nothing at idle. Almost sounds like a rod when there going bad...haven't pulled the oil pan off to check the rods just yet. Hoping it is not that
This really sucks to still have all the problems I am having...oh wait I have a DSM..
...I have to keep my sense of humor or I burn this car
