matt_c
- 0
- Aug 16, 2013
el paso,
Texas
Its a black car. The one that I was told it had the turbo removed but in the end it never had one
ts to use and where to mount it.... im kinda confused text me at 832 622 5887hey guys im trying to mount my engine on a stand i got from harbor freight and was wondering if any one had any idea on what bts to use and where to mount it.... im kinda confused text me at 832 622 5887
hey if ya get a chance text me the pic
Based off your mod list the car is converted to a N/T. Is this still the case?
Next check to make sure you're not burning any fluids off. As well make sure that fluids aren't being mixed (ie water in the oil or oil in the water). If any are dropping then I'd start looking in that direction Valve seals, rings and turbo shaft seals (if it's still on) come to mind for oil. A head gasket is likely if your losing coolant. Let us know and we can tell where to start looking from there.
If its as bad as you say i'd lean toward rings.
Thank you GST2012GSX very well explained. Definitely post the numbers up so we can see what's going on.
How To Perform A Leak Down Test - EricTheCarGuy - YouTube
915DSM:
This guy is pretty good at explaining the leakdown test. Maybe if you pull the plug next to the other cylinder you might get some noise indicating a bad HG. However, when I look at the compression test it doesn't toss out any obvious hey look at me HG signs. Two things I'd look at right off. For the stalling is the BOV being recirculated with the Evo MAF? The only two systems that can compensate for the drop in airflow that quick are a GM MAF and speed density, as the air is measured after the BOV. The second and it's kinda iffy is the CX racing intercooler for the psi drop. I'm not knocking it, but it seems almost questionable as if the IAT's are creeping up and dropping off airflow, Like I said iffy.
If you're running a composite, it almost becomes a throw parts at a problem solution, "sure take it off, measure it, and pop another gasket on" solution. And even though my personal record for taking a 4G63 head off in an hour is good it's painful for naught.
Is this a sign of head gasket? Should I change it? Or can I finish off a tune with it like that since its in the moderate stage?
The purpose of a leak down test is so you dont have to ask this question or take a shot in the dark. While doing the test, with your oil cap and rad cap off listen/watch for bubbles. If you see bubbles in rad fill neck, or hear bubbles from your oil cap fill, then your head gasket is bad. If you just hear air coming out of the oil cap but no bubbling then thats your rings.
This case is non of what you say. If you read my first post, I mentioned its leaking adjacent to the cylinder been tested, not elsewhere.
But thanks anyway.
Hey this is for everyone interested on seeing a fellow Dsmer I know who will take his 1g tonight to the track.
Its a 1g N/T converted to turbo. He has some good mods and is shooting for low 13s.
Anyone wanna go?? we will head over there around 8:30.
