EGT Reads 125 when unhooked?
2gGSX
1,956
31
Feb 15, 2004
St. Louis, Missouri
I just bought a used (100 miles) EGT from someone off ebay. Autometer cobalt for 87 dollars, probe looks barely used so I think I got a deal :thumb:
Back to the question, it is reading 125 right now, unhooked in the box. Can someone explain this or did I get screwed?
It uses an electrical signal, its not out of calibration or anything. All is well.
If it were mechanical I'd be worried!
still seems odd to me - but now that im thinking about it
my EGT gauges used to just go were ever when it didnt have power on it also.
Everything is fine. You can see mine is showing almost 400 degrees and trust me I keep the apartment a little cooler than that.
Thanks guys, just gotta put this on the list of parts to install now :d'oh:
I got mine installed today and notice the same thing, each time the turn the power on and off the gauge moves up abit
My EGT do the same...when I turn off my key,that small "finger":) jump down from 400 to 350..
I heard about calibration.. How does it work? What I have to do to work wel?
Sorry for Bad English
You don't need calibration.
My boost gauge does that also.
For electronic gauges it's fine.
Most electrical units use cold junction compensation. It is automatic correction for ambient temperature changes at the cold junction of the thermocouple. The temperature you see is what the gauge/sensor is reading for ambient temp.
If your gauges 125 F and is mechanical (using a capillary), that means the unit is definately out of calibration as it should only be at room temp. (if the scale goes that low) mind you alot of these cheap gauges are really only accurate in the middle 2/3 of scale anyway.
