selmerguy
- 1,810
- 23
- Nov 14, 2004
Killeen,
Texas
i got my egt gauge today. autometer carbon fiber. anyway it is in the package and the needle rests on about 120 or so. is this right? or should it be on 0
selmerguy said:just making sure here. on the 420a motor i should tap the # 4 cylinder right. looking at the motor from the front of the car it is the one on the right, correct?
That's #1, and yes, that's the traditional sensing point for those unafraid to feed molten thermocouples to their turbines.selmerguy said:just making sure here. on the 420a motor i should tap the # 4 cylinder right. looking at the motor from the front of the car it is the one on the right, correct?
Defiant said:That's #1, and yes, that's the traditional sensing point for those unafraid to feed molten thermocouples to their turbines.
Others choose to mount after the turbocharger.
No, dammit, my mistake. I forgot about the 420a being reversed. Duh me, my apologies. I'm very old, can you help with this diaper?selmerguy said:sorry i thought you counted starting from the timing belt side to the tranny side like on a v8. in witch case it would be #4 but thats a petty point. i got it done and ended taking off my manni to clean it out.
Defiant said:No, dammit, my mistake. I forgot about the 420a being reversed. Duh me, my apologies. I'm very old, can you help with this diaper?
i should get a green square for that oneDefiant said:No, dammit, my mistake. I forgot about the 420a being reversed. Duh me, my apologies. I'm very old, can you help with this diaper?
SnoopySLR said:I agree with defiant. Mount it in your DP... I wouldn't want it to break and go through my turbine... that would suck. I mounted mine in my DP, about 6 inches from the turbo.
Also, about the needle floating, hook power to it and see what happens. It should go right to 0
