egr and t-b question?
kingdaniel04
36
Sep 2, 2004
phoenix, Arizona
hey guys all i need to know is: can i unplug all the vac lines to the egr valve and be ok? the block off plate is not here yet but i decided to start the vac lines clean up,soo will i run into problems if i leave it out vacum for now ### it has like 3 vac lines just going to the egr?
second: the car is a 90 and the t-b is diff from the 91-94(duh right) but now that ive started the vac line clean up,can i plug all four vac holes on the t-b? just because their in different locations...
thanks guys,i did search and all i can come up with is the vac diagram from taboo but utalizes a 91-94 t-b which is what im going off of right now!
thanks
Yes, if the EGR is working correctly, it's closed until it gets a vacuum. So, no vacuum line means it'll stay closed.
