ECU upgraded (420A) and shipped back?
JRichter
225
Mar 27, 2004
Colorado Springs, Colorado
Has anyone checked this out or know anything about it?
Link for product
Company claims to upgrade your ECU and ship it back for good gains (420A motor specific).
I searched this forum for anything on this briefly and found nothing. If I missed a related thread please direct me to it.
Thanks for info.
if it were truely 420a specific then the guy would know that we DONT have a speed limiter. also an ECU does not go to the dealer to get the vin or mileage program EVER. it is a scam. each year of ECU is different from the others and the 95 ECU's are like caomparing apples and oranges. the ONLY proven ECU upgrade we have besides a $1,000 standalone unit is the AFX ecu, and unless your a 97 forget it.
if the mod were true he would have an established shop, and we over at 2gnt would be buying it. however he is pawning JUNK on ebay and taking advantage of the non-informed..if you want usefull info- go here- 2GNT
[/URL]
ECU's DO require programming depending on the vehicle. It's NOT a scam because there are tons of vehicles out there with alot of computers on them and until the Body computer or Engine controller is programmed with the VIN, Sentry Key Code, or other information such as pinion factor and told that it has cruise and A/C, then the computer will not work right. The options on the car will not work and the speedometer will be off. This is NOT a scam. And the mileage DOES have to be put in using a dealer scan tool. By sending YOUR computer, no visit to the dealership is required in order to program these things back in.
Note: I am NOT vouching for the quality of this product nor am I promoting it.
these things have worked for other cars when they come from actual reputable companies. however this is not one of those...henceforth this item sold on ebay is a SCAM...if you think otherwise have a chat with dino..he'll set you straight.
I was NOT disputing the product or it's seller. I don't deal with Ebay, with this seller or the product.
I DO work at a dealership and have to program mileage and other options in to new computers on a regular basis.
Whether this is a scam or not, I don't care. What I do care about is mis-information being posted out here and that's why I piped up about the technical aspect of this product. ECUs, BCMs, SKIM, and TCMs needing programing (depending on the vehicle) is not something I need to go ask someone else about. Thanks.
Doug
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
