ECU question
ge-du-racer
Mar 28, 2004
hell, Michigan
Will an ECU from an AWD work in a FWD car? I thought it was all machaincal. It was from a 91 AT AWD to a 92 AT FWD. It did NOT work! Shuld it have and I have some other problem or is it exact swaps only????
Thanks
-Jeff
Thanks
-Jeff
Thats weird. I got an EPROM ECU from a 91 FWD car and it worked just fine in my 92 AWD car, both 5 speed. I would look at the ECU itself and see if the one you got has bad caps or other internal problems. Thats all I can think of that would cause it to not work correctly.
Michael
:laser: :talon:
As long as they are both from a car with the same transmission, they will be fine.
All 90 MT ECU's are the same
All 91-94 MT ECU's are the same
All 91-94 AT ECU's are the same
However, some may be california emissions, which can be removed with a simple resistor change.
