ecu pins. what parts store sales them?
kccombs
236
Oct 25, 2011
wichita, Kansas
Well im doing the 2.0 nt to turbo conversion for my 92 talon. And all i have left to find is my 3 ecu pins. I heard that you could go to radio shack and find something. But not sure if that would be false or true. I know i could get them from another turbo dsm that is getting parted out. Bit dsms are rather scearse where i live and theres just not people parting these cars out. Any info wod be a live saver.
I dont actually have a picture of the pin. But they are the ecu pins that should hook into the ecu plug that way iwill be able to run a wire from them to the maf, fpr, and for the knock sensor.
You should pull one out and snap a photo. I've seen a couple different style ones that plug into the Mitsubishi ECUs, and if you had a picture, someone on here would probably just send you what you need.
You do need a turbo ecu to do all this. So the pins should be their already?
He probably means the female ones on the harness.
  • Wanted 6 bolt NT water pipe
    • chrisman287
