Ecu fuse blowing issue on 91 TSi
ZeroRain
40
Apr 15, 2005
South Bend, Indiana
Hello friends!! Im running into an issue with my 91 TSi. Now the car ran fine, pulled up to the house, shut her off and went about my day. I went back about 2 hours later and tried to start her, no go. Started going thru everything, and found that the ecu fuse, 20 amp, had blown. I replaced said fuse and started the car. It started fine and ran for 10 seconds and dies. I check it right away and it done it again. I replaced the fuse and also replaced the ecu with a spare I have. Turned the key to run and waited. It blew again. While cranking the car it has fuel pressure so I dont think there is any short in the fuel pump wiring. I visually spotted around the wires and cant see any issues. Any ideas??
Thanks
Zero
I found my problem guys! After unplugging everything I could think of related to the ecu, then plugging things in one by one until the fuse blew again, I found that the O2 sensor was causing it. The o2 I used was a universal I wired up. I soldered and heat shrunk the wires then made a nice tape loom. Apparently the heat shrink wore a hole into each other and caused a short on the heater side. So I reheat shrunk, taped, then made a new tape loom and problem solved!
Zero
