Talyn
- 441
- 19
- Jun 10, 2012
Pittsburgh,
Pennsylvania
Here's the deal, some time back after doing some work to my car it wouldn't start, I did some visual checking and found the wires to the ECT snapped right at the terminal end(ie. nothing left to splice back together). Naturally I went out and bought a connector, but it was an oval style connector and did not fit correctly. But everywhere I looked showed the oval connector for my car, thinking that maybe the owner swapped sensors or harnesses at some point, I decided to just get a new sensor to match the new connector pigtail. Well when it was about 40* out it was reading -14, and fully warmed up reads about 150, which I know can't be right, because my gauge which has never given me reason to doubt it(comes to temp normally, and has gone hot when I have legitimately overheated).
And because of this my fans won't kick on, and it actually made me overheat in traffic earlier today, I am also running so rich, that if I accidentally stall it out my plugs foul out instantly, I suspect because of the ECT.
While searching tonight, I did come across this thread:
http://www.dsmtuners.com/forums/newbie-forum/328009-resolved-2g-coolant-temp-sensor-question.html
Which seems to suggest that my 96 talon got an eclipse ECT sensor and harness. That being said, the very last post in this thread seems to suggest that the two different sensors are not cross compatible. Anyone else run into this problem?
Managed to connect the old sensor to check what it was reading, and it was correct, so if anyone else comes across this thread, do NOT switch ECT styles, it WILL read differently, in my case, I have a 96 talon TSI AWD, but the correct connector and sensor for my car are those listed for a 98 eclipse, at least on napa's site, not sure if the one listed for a 98 talon is the same or not.
