eclipse doors same as talon?
they are the same.
i think even avenger uses the same door. (aleast i sure the dash are the same)
darren
So here is my problem. Some one backed into my door. I have a 95 eagle talon. the door trim is slightly bowed an can be replaced if need be. But I found a door of a 97 eclipse will this work on my car and if so do the trim holes line up to put the trim off the talon on the eclipse door or is the eclipse trim the same. please help me out thanks.
^^^ false ^^^ and 97-98 talons had side skirts but no door trim...
this question is easy to answer, hopefully i can word it right so you can understand it...
95-96 talon door trim/side skirts (this is what your car currently has)
97-99 eclipse door trim/side skirts (GS through GSX had these)
97-99 eclipse RS (notice no door trim or side skirt)
what im trying to say is IF the car isn't an RS the trim off the 97 eclipse will work on your car however, it looks nothing like the trim that will be on your other door.
:dsm:
The door I found to replace the talon door is off a 97 eclipse gsx and sense you say It will bolt up to my talon Tsi like the one pictured above. the only thing that will be different is the side door molding? but will I be able to put to door molding off my talon on the eclipse door? do the holes line up for the clipse that hold the panel on? Thanks for all the help
Also for future reference all 95 - 99 Eclipse & Talon doors will interchange. with the only difference being the holes drilled for the side spears on 97 & 98 Talons, and lower holes drilled for the 95-99 GS GST GSX & 95 96 TSi TSi AWD door skirt caps. as mentioned above.
You have manual windows and power windows. Also the doors off 95 - 2000 AVENGERS will fit but you will need to change the door glass and mirrors. Avengers 95 & 96 the body door edge guard moldings are stick on and can be peeled off easily, on 97-2K the door edge guard side moulding are plastic riveted on and when removed will need to fill the holes.
The interior trim panels will all inter change with power windows. All Manual trim panels will fit manuals.
95-99 Eclipse Base & RS has no side molding nor side skirts
95-96 Eclipse GS GST GSX has side skirts with door caps 1st design
97-99 Eclipse GS GST GSX has side skirts with door caps 2nd design
97 & 98 Base Talons had NO door spears or side skirts.
97 & 98 Talons had door spears on ESi TSi TSi AWD and no lower side skirts.
95 & 96 Talons had no door spears or door guard moldings or skirts
95 & 96 Talon TSi TSi AWD had lower twisty door caps with side skirts.
:dsm:
HEY! That pic is copyrighted! LOL jk. Was kinda funny seeing my car in a thread. ^^ completely right about the doors
