1G Ebc issue
91tsiawdtalon4g63
168
24
Dec 24, 2013
Brownsville, Pennsylvania
Have a Mac 3 port hooked up, hose diagram is correct (both top and bottom holes used on wastegate), one wire to pin 105 of the ecu with full continuity from ecu to ebc, hooked up to 12v power with full continuity to ebc, enabled boost control on ecmlink, put duty cycle between 0%-75% and it did not change the boost amount from wastegate pressure (24lb 44mm mvr tial). Checking the wires with a multimeter I found that both wires are receiving battery power 0-75% duty cycle and also receives battery when 100% duty cycle is turned on through link (should switch to ground when 100% duty cycle is on). I just recently had the ecu serviced through ecmlink for a blown driver (ic106 aka ebc driver) PRIOR to installing the Mac 3 port. Visually inspected ecu and everything looks how it should be. The ebc isn't being grounded via the ecu (ebc clicks when grounded manually so it functions correctly). I have no idea why the ecu is not sending a ground signal to the ebc and any help would be appreciated greatly.
Turbo is an fp black if that matters
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
