Early symptom of crankwalk or not???
GsxProject
63
Aug 24, 2006
Brooklyn, New York
I've started my car up after letting it sit over the winter and noticed that the crank pulley is wobbling! My question is if this is an early symptom of crankwalk or not. The car idles fine and it's doesn't seem to be affecting the way the car runs or drives. Also i took a pry bar to see if it the bolts were loose but the pulley didn't budge out of place, but my biggest concern is if this symptom is crankwalk or just a couple of bolts loose??
The crank pulley is 2 pieces with a rubber damper in between the two. You need to replace the crank pulley before it causes other problems.
I went with an underdrive pulley instead and i suffer no side effects and dont have to worry about a pulley separating anymore.
That's exactly what I did, I got a uderdrive pulley and put it on. Now my soul is at ease, thought that would've been the death sentence for my engine. Thanks a lot guys!
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
