Early 90 TB ?
green97gstspyder
143
Mar 14, 2012
newark, Delaware
I found an early 90 TB today in the junkyard but it is the one with only 2 vac ports instead of the one with 4. Can this still be used on a 2g with a 6 bolt swap since I already have the 6 bolt manifold or should I just stick with my 2g one?
I found the how to swap and it says the one I have wont work but I searched and searched and can't find out why. So if someone could shed some light on this for me I'd appreciate it. thanks in advance
The 90 is a 3 wire with an external idle switch.
You will need to take that 4th wire from the 2g harness and run it to the external idle switch on the 90TB.
I plan on using link to simulate the idle switch but i dont know which wires to hook to which ones on my 2g harness since they are all different colors. The ones on the tb are all green each with a different color stripe and the ones on my 2g harness are yellow, red, and i forget the other two colors
Thank you for that link I'm checking it out to make sure it worked.i just gave up on this until now. Thanks again campos
