RipperXX
- 5,788
- 172
- Feb 23, 2003
Royston,
Georgia
Eagle & Scat rods are about the same price, and unless I am wrong they are both about as strong as one another so which would you go with?
i run scat/weiscos in my built 6-bolt. i did a lot of research at the time and the only difference i could find was that scat kept same stock oiling hole under the piston end of the rod were eagle didnt. mitsu engineers put that oiling hole for a reason so i figured id keep it.
I was so set on getting eagle's. Scats rods hust sound better.I would state that the Scat H-beam rods are comprable to the Eagle H-beams, as they are nearly identical in all aspects.
Not quite. I've seen some nasty stuff come out of both of their facilities. I've seen more quality issues with Scat than Eagle. I had a customer that had some issues with a scat rotating assembly that I sold him. He sent it back to us for inspection, and I was baffled to say the least. I almost needed a tetanus shot after handling the thing.Scat rods are basically eagless except Scat actually checks them before they go out the door. With Eagles you may get rods that are too close to out of tolerance for my liking. SCAT gets the vote for better quality control.
It's not that important at all. Our engines have oil squirters to keep the pistons lubricated. With the Eagles (and any other rod that doesn't have an oil passage), the oil will simply escape via the clearance between the rod and the crank journal. In many cases, this oil spray upward, lubricating the walls, rings, and pistons anyway.Let me rephrase: Is the oiling hole important enough to justify the extra few dollars?
Do other rods block/create this hole?
I am using Eagle H-BEAM rods.
Well, if you're shopping by price alone, then it's a baised opinion, because many others can find good deals on either.Just another reason why I chose the SCAT rods, less then $300 and rated to 950 hp, check out this add on ebay, not that I know this particular company. Just wanted to let everyone see that H beam rods (eagle, scat, whoever) are good for way more then 600hp, as twicks69 can vouch for......
