forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Anyone else having issues with the rubber around the fuel cap swelling? Using a new POLY RCI 12 gallon cell. Red plastic cap with a rubber grommet/gasket type seal around the cap. When new the cap fit great. Now I literally have to use a screw driver to pry the cap out of the cell. And then use a screw driver to stuff the rubber gasket down around the cap to get it down in its receptacle enough to lock the cap. Ive tried coating the rubber in silicone spray, didnt help much if any. I resorted to carrying around a small screw driver and spitting on the damn thing to get it to seat properly.
Anyone else having issues with this? Know of a solution? Possibly different gasket material? This cell claims it can be run with methanol, so I dont see why the gasket is swelling.
On a side note Also noticed the hardware securing the cap ring to the top of the cell is already corroding.
Anyone else having issues with this? Know of a solution? Possibly different gasket material? This cell claims it can be run with methanol, so I dont see why the gasket is swelling. On a side note Also noticed the hardware securing the cap ring to the top of the cell is already corroding.
