Dump tube help
david harker
30
Jun 11, 2014
Hagerstown, Maryland
Ok so I have a Garret gt4094r and tial WG and my dump tube actually comes out of the hood , I want to reroute it . Can I had a sleeve and clamps or will it have to be one solid piece like flex pipe or something ?its not welded now . And it doesn't leak actually . I did not cut the hole in the hood , the other owner did . As you can see the dump tube come out of the hood .
get one solid piece clamps are going to cause exhaust leaks and look like poo . The dump tube is immeadiately after your exhaust turbine the exhaust gases are at their high velocity and will blow carbon all through the clamps and engine bay. The garrett flange is common check ebay or vendor for a downward dump pipe
