Dumb wastgate dump idea
Moparbishi
112
Sep 15, 2007
Fremont, Nebraska
I drive a 98 AWD Talon and I recently just put on Apexi N1 downpipe and catback with an open wastegate dump. Is it just me or does it sound nasty when your half throttle like a bad exhaust leak. I dont even want to accelerate next to a car cause it sounds gross. Any way my dumb idea is to stick an ebay turbo whistler in the dump. It might muffle some of the raspy sound and might sound cool. Comment and Criticism please.
im assuming you have an internal wastegate dump? those tend to sound pretty nasty/crappy. in my opinion you shouldnt dump an internal, but externals are much more controlled, and sound 100% better than an internal dump.
Hmmm. I love the way it sounds, but I know what you mean about how it sounds like an exhaust leak when it's partially open on part throttle. I wouldn't do that whistle thing in the exhaust, I do'nt know how that would sound.
I would just go with a tubular recirculated o2 housing that Megan Racing sells for ~$75.
Technically it is an exhaust leak. :D
I'd love to know how it sounds with the whistler.
thats obvious it sounds like shit. but i figure that if it is going in a dump tube that is only an inch and a half dia. Plus the wastegate pushes out alot more rushing exhaust than the tail pipe. 20 bucks shipped, doesnt hurt
Have you tried looking for something that will just straight muffle it? I don't know if could get your hands on anything like an ATV muffler or possibly a small bike's, but that might even work without causing too much back pressure.
Maybe i'll try it with my gutted-out hayabusa muffler :p.
I vote for a little muffler or some steel wool up in the pipe. The ebay whistlers sound awful, and you already have a real turbo that gives you the spool up sound :D
The whole advantage of an open WG is that there is no volume restriction from the expelling gasses and that there is a constant volume in the turbo's exhaust. Putting a restriction in the WG would negate that advantage. I've always liked recirc more.
That's why I figured a mini muffler - very little restriction as it bypasses the rest of the exhaust but still cut out some of the sound.
You know it might even be that it's just the vibration of that tubing itself. Have you tried wrapping the outside of that pipe to see if it cuts out on some of the sound?
  • Wanted 6 bolt NT water pipe
    • chrisman287
