Dumb question about fuel injector removal
calcifer
219
Jun 2, 2004
O'fallon, Missouri
how do you get the electrical plug off of the injectors? I don't see any release, but I'm afraid to pull to hard as well. what do i do?
There should be a little metal clip on the plug....about as thick as a paper clip. Use a knife or a pick to pry gently from the plug. Just dont lose it, it needs to go back in the plug when you hook it back to the injector.
Yep, I just found that! Thanks for your help!
Just make sure that when you're connecting the harness back into the injectors to put it in facing the right way, and hopefully they will be discriminated enough, but make sure also that you are absolutely correct in lining up the wires to the correct injectors!! Good luck!
Ben :talon:
