dsmlink??
Status
Not open for further replies.
NJgsx
90
Nov 11, 2004
mountainside, New Jersey
hey wat exactly does the dsmlink do ... im havein fuel problems and im wonderin wat it does :dsm:
Its virtually a standalone engine management system that is built into the stock DSM ECU in order to retain a user friendly interface and stock fuel and timing maps, as well as the other benefits of using a stock ECU. You can control timing, fueling, airflow, you have stutterbox, antilag, no lift to shift, you can disable certain CEL's such as emissions which allowing the rest to be read, you can log things about 10x as fast on DSMlink as you can on the good old PDA datalogger. Its basically an engine management system with a datalogger, so think of it as an Safc+PDA+Logger+everything else I named. You must use an eprom ecu, which means for 2g's you have to have a 95 eprom ecu, and for 1g's you just simply have to have an eprom ecu.
'Nuff said.
This has been discussed more than enough times on this site.
That being said, try to type like NJ still teaches English.
Status
