Dsmlink with a 97 ECU
FastRthenU
582
Dec 15, 2002
I've been reading up on using older ecu's in 95, adn vise versa. I was wondering if I could get some feed back on this topic. I want to know if there is a possibilty of using my 97 ecu with Dsmlink v2. Can I just change the firing order, ans invert the CAS signal? thanks
No you can not use your 97 ecu it is not an eprom. You will have to have a 95 ecu.
Correctimundo. You NEED a 95 EPROM ECU. No EPROM = No DSMLINK Chip insertion.
