Dsm free mod sleepy eyes headlight mod Question
minimoose
297
Jul 24, 2011
Bourbonnais, Illinois
Hi did the sleepy eye mod on my 90 talon a while ago and just wondering if when you turn the lights off adn they go down why my passenger headlight freaks out and goes up and down multiple times then goes down and stays down , is this bad?
Sounds bad, I just do mine temporarily for car shows and such. How do you do yours? I pull the fuse and hand adjust mien to the height I want, then when bringing it back to stock I plug in fuse and hit the button to lift the lights. That will reset them. When I do reset them, it occasionally will go up and down twice before resting at fully closed, but It will open just fine again in the future. You make it sound like it wont come back open gain.
on mine i pulled the chicklet fuse on the passenger kick panel harness and ive never had a problem it may be you headlight motor going out.. theres position sensor inside the motor and when it comes to a full stop it changes voltage and tells the motor to stop.
